Brief Description: Layout trim and rivet line on LE skin
Marked a line100mm back from the top rear forward edge at each nose rib location. Extended the center rivet lines back also. Clamped up the skin and once it was positioned well, marked the rivet line at the edge of the LE skin. Marked a line forward 78mm from the 100mm line on the LE skin as the trim line.
