Flipped wing over and setup for the bottom skin. Got main spar level, the set it at 9 degrees, used angle cut blocks on top of the steel beams to adjust the 9 degree angle. Check rear spar and it was level. Layed out rivet lines on main spar and positioned skin. Got one pilot rivet line set on the main spar and called it a night.
