Brief Description: Rear Top Wing Skin Fitting 1 of 4
Fit skin and marked through the pilot holes to the skeleton below, looks like it can move rearward a little and over hang the rear spar 1 or 2 mm. That puts the rivet lines in the best place and I can trim the rear skin edge easy enough.
Extended two lines on the skin along the edge of the pilot holes, it makes lining up the rib lines on the spar easier to see.
Taped skin down to main spar starting in the middle and worked out towards each end one rib at a time.
