Ron Lendon's Aircraft Mfg.
Date:  4-21-2008
Number of Hours:  0.80
Manual Reference:  6-W-7A
Brief Description:  Rear rib assembly process 1 of 3
Locate rear rib and space evenly between spar caps top to bottom.
Line up the line and mark through spar web pilot hole.
Remove rib and center punch the one hole, I started with the top hole first.
Position rib
Position rib
Line up line and mark
Marked line
Marked line
