Ron Lendon's Aircraft Mfg.
Date:  9-13-2007
Manual Reference:  6ATO-1
Brief Description:  Wired aileron trim tab servo in wing
Bent up a piece of scrap aluminum as a heat dam. This allows you to shrink one wire connection at a time and protect the others from overheating.
Image 2) The servo is held with rivets and the help of washers to protect the plastic housing. Have a service loop of wire inside the aileron in case we ever need to replace / repair the servo.
Heat dam for shrink tube
Used washers for rivet holding
Trim tab hooked up.
Trim tab hooked up.
