Brief Description: Finished aileron stops, fab light fixture
Finished both and attached the left aileron stop.
Image 2 & 3) Started working with the new welder and began putting the pieces together for the AeroFlash nav/strobe/pos mounting fixture. Need a little more welding practice but it is going to be real nice having this at home. Decided to fab this up after failing to form it. Nice thing about aluminum is you can weld and grind it till it resembles what you want it to be.
