Ron Lendon's Aircraft Mfg.
Date:  3-11-2007
Manual Reference:  6LLO-1-6
Brief Description:  Strip for lower lens cover screws, Wing Locker
Took a picture of the outboard end of the lens to try and show the slight angle cut on the lens. Anyway, opened the lens holes to 1/4" and made up a strip out of .032 6061-T6 for the screws in the lower lens. Got it all in place and started on the wing locker.
Image 2) I told Anne the wing locker is actually shoe storage, she has a thing for shoes, started the cut by poking holes near the corners. This layout is 35 mm away from final trim. Jus like always start in one corner and snip a little bit with each hand. I started in the lower right of this picture and cut up then left.
Image 3) Hole is open now and I cah reach in and transfer the rib and flange edges to the top skin. to layout the actual hole
See the slight angle cut?
Wing Locker, holes in corner
Wing Locker, first cut
