Brief Description: Prep for primer bottom left wing
Layed out the land/taxi light opening. Removed the LE skin. Removed the nose ribs. Put the tack rivets back in. Flipped the wing over and set it up in the fixture again. Removed the bottom rear skin and flap hinge.
Image 2) Pulled off the rear bottom skin. I ran out of black clecoes so it must be time to rivet some of this up. Wiped it down with alcohol after deburring and slapped on some primer.
Image 3) Same for the nose skin. I am going to hold off cutting the land/taxi light hole till after the bottom is riveted.
