While the top was down in the fixture I back drilled all the lower nose ribs and fille all the holes with copper clecoes. Next lifted the entire wing assembly above the table and removed the fixture and flipped the wing over and set it on three of the 2 x 2's with 1/4" poplar strips on top of the risers.
Image 1) After it was flipped over , remove the tack rivets and noticed it shift a little. Put clecoes in the entire spar cap line, every thrid hole and drilled the rest, the rear wing skin is the template. Removed all the spar cap clecoes.
Image 2) Slipped LE skin under the rear skin and lined everything up with light tension on the straps..
