Brief Description: Make fixture for wing light lens
Just used 2 x 4 spacers actual measure was 1.5 inches on the left and 1.375 on the right end. 3/4 low quality MDF on the bottom and a slightly warped piece of 3/4 plywood was the top, Next, position the blocks then the banded piece, clamp the right end first, then clamp the left end.
After clamping to the stops, remove the clamps and see what we have.
