Brief Description: Open rivet holes to A5 rear bot. left wing skin
Needed to flip the wing up to retrieve some black clecoes from the top wing skin. I marked the position of all the risers then flipped it up and braced it with an L angle.
Image 2) 1 cleco and some clamps on the table help it quite steady. Removed half the clecoes from the top skin.
Image 3) Had about 7 clecoes per rib to use. Worked from the rear and kept moving forward one line at a time. Ready to layout the outboard ends and holes in the bottom skin.
