Brief Description: Drill and cleco Outer Spar Cap Angles
Made a setup block for the .5mm distance using a small piece of spar cap with .016" material two way taped in place. I used a screwdriver from below to pry out where necessary. Once in position drill and silver cleco to the table. Working from the center I went out about 12" for the next hole then came back between the two clecos. Worked this way all the way to each end.
Ready to open up the holes on the drill press now, one side only.
