Ron Lendon's Aircraft Mfg.
Date: 8-17-2006
Number of Hours: 1.00
Manual Reference: 6W1
Brief Description: Assemble and rivet Flaps Step 8 & Clean up
Fixture flaps bottom side down and strap to fixture. Rivet working from the trailing edge rib 4 rivet, then rib 3, rib 5 , rib 2, rib 6, rib 1. Then move to the next rivet line forward and follow the same process, rib 4, rib 3, rib 5, rib 2, rib 6, rib 1 . . .
8th step
Bottom of flaps
Top of flaps
