Ron Lendon's Aircraft Mfg.
Date:  5-23-2007
Brief Description:  Setting up 10" Delta Band Saw
Bought a 10" Delta Band Saw from Lowes. It is a high speed direct drive and needed a little adjusting of the lower wheel to remove the vibration. I used a surface gage for the initial adjustment and will use a tenth indicator when I get the tool box back home from GM.
New 10
New 10" Band Saw
