Brief Description: Finished bottom side of Elevator
Finished riveting bottom of elevator. Pulled hinge pin and oiled it with motor oil. Making sure I can get it in and out. Had to tap it out with pin (welding wire) then used needle nose locking pliers and tapped it out by pulling it.
Reinstalled it using drill motor spinning lubed pin.
