Ron Lendon's Aircraft Mfg.
Date:  2-22-2009
Number of Hours:  1.60
Manual Reference:  WW Nose Bowl
Brief Description:  Make small disks from MDF for inlets
Pilot drilled center through blocks and marked circle with tool bit on the lathe. I use a piece of PVC to hold pressure against the block while the center was piloted with a 3/8 bolt in a three jaw chuck.
After marking, sawed the rough circles.
