Ron Lendon's Aircraft Mfg.
Date:  1-5-2010
Number of Hours:  1.50
Manual Reference:  WW Carb
Brief Description:  Make tool to remove float seat
Cleaned up table and put things away.
Tried to remove check valve orifice from bottom of accelerator pump and broke it. Going to have to tap it out after getting the correct orifice so I can measure the threads.
Making a tool to capture the ID, OD, and slot. This baby has been in there for a long time.
ID shank turned +.01
