Ron Lendon's Aircraft Mfg.
Date:  1-4-2010
Number of Hours:  1.60
Brief Description:  Remove rivets from Center Spar
Removed the A5 blind rivets.
Center punch, Pilot drilled, #30 drilled all solid rivets.
Knocked heads off with chisel, seperate web from spars.
Punched out rivets with 1/8" pin punch on the floor supported on end grain wood blocks.
Wire tied pieces together.
