Ron Lendon's Aircraft Mfg.
Date:  8-28-2009
Number of Hours:  1.00
Manual Reference:  6b20-4
Brief Description:  Layout, cut, and bend air vents 4 of 5
Tried several ideas to make tube to hold duct tubing. Heres one from an L-Angle drilled about every 8-10 mm and split up the flange. Wrapped it around a 2" pvc pipe and stuck it through.
Think I can do better, off to Lowes Aircraft Supply.
