Ron Lendon's Aircraft Mfg.
Date:  8-30-2007
Number of Hours:  1.00
Brief Description:  Falcon Heads and ACS packages arrived
The Heads from Falcon came back in two boxes UPS Ground marked Fragile. Mark packed em real good, Glued and taped the boxes closed. The outer packing material is the pink foam board used in house construction. The inner packing is paper.
