Ron Lendon's Aircraft Mfg.
Date:  6-22-2012
Number of Hours:  1.00
Brief Description:  Two Minute stress test
Set this test to see if everything is safe for flight. This is the attitude my first flight takeoff will be, it's about 10 degrees on the instruments.
The test is run for two minutes wide open throttle to represent climb attitude to make sure it can do it. If this passes the same test in the air will take the airplane up to around 2000' AGL.
Tie down chained to the earth
Mains chocked
Mains chocked
Nose wheel blocked up
