Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Assemble rods to crank
Cleaned the crank journals and lubed cam and crank with assembly lube. Torqued ARP rod nuts to 27 ft lbs with moly lube on the threads.
Test fit the heads to determine which head bosses need spot facing.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
