Ron Lendon's Aircraft Mfg.
Date:  11-28-2012
Number of Hours:  1.00
Brief Description:  Remove pistons from rods, check piston size
Made mandrels to push pins out with the small arbor press. To hold the press down I used weight of my Vans front tire and some 2" square steel tubing I had laying around. didn't take any pictures (sorry).
Measuring the pistons with dial calipers, fix left, undersize right end and rotate right end for size. Just hunting for the smallest and largest pistons.
