Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Airflow through Cowl
Now the air inlets are 4.9" in diameter with a 7 degree venturi flange on the inside of the inlet. The area for the inlet time two is 37.715"
The exit is basically made up of 4.25 x 17.7 rectangle and two 2 x 3 triangles for a area of 78.25" combined for the exit.
37.715 / 78.25 = 0.4819808306709265 or invert
78.25 / 37.715 = 2.07477131114941
for twice as large exit area.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
