Brief Description: Aileron trim and gascolator heat sheid
Finished wiring and testing the aileron trim switches. Putting the nut and washer on the back side, I used double backed tape and stuck them to the backside of the instrument panel. They held and made assembly much easier.
My heat muff is as long as I can make it and it was kinda close to the gascolator, so have discussed this with knowledgeable others, this is the fix. Made templates for a heat shield around the gascolator, then fabbed it up with .018" stainless steel.
