Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Documents holder, pitot plumbing
Cleaned up the table and made a document holder for the right side console. Glued rubber seal along rear edge to prevent chafing on the fuel lines.
Rats nest behind instrument panel but it all works. Added the pitot/aoa plumbing.
Mounted seatbelt hardware for the lap belts. Need to machine a 1/2" long 5/16 od x .25 id times two.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
