Ron Lendon's Aircraft Mfg.
Date:  5-21-2012
Number of Hours:  5.00
Brief Description:  Remade the upper elevator cable
Started by re-doing the double spiral warp safety wire with single wrap. I just didn't like the way it looked.
Remade the upper elevator cable (1.5" shorter) and got it in place.
Little trick for saftey wire on the lower turnbuckle, get it all set, loosen and remove the top cable from the control stick, remove upper cable from elevator, remove the control stick and saftey wire the lower turnbuckle and bolt it in place, replace the control stick and re-attach the upper elevator cable.
Snaked the string from inside the left wing for the aileron cables.
