Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Seal canopy flashing with sikaflex gray
Tape off area not to be stuck and to protect the canopy while abrading the bonding area with 220 sandpaper.
Open the joint area by removing the screws along the flashing.
Apply caulk/sealant/adhesive.
Put the screws back in. Clamp the end areas.
Wipe in fillet with fingers, let dry.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
