Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Rudder and right wing close to done
Fabricated the rudder stops and set the swing.
Test fit the wing and decided to place the rear spar bracked inside the wing. Moved bracked back to the original position.
Connected fuel line and wires on the right wing. Even the fuel gage works.
Ready to set up the splice on the aileron trim tab.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
