The rear spar attach plate needs to move rearward so it will be on the outside of the wing spar. Measured and tweaked the plate with masonite and large cresent wrench, little at the botton, little at the middle, and a little at the top till dimension was right.
Crimped Knife Splice connectors to all the wing lights. Stripped both ends of the alieron trim tab cable.
