Ron Lendon's Aircraft Mfg.
Date:  4-29-2012
Number of Hours:  2.16
Brief Description:  Hung tail feathers
Re hung the elevator and routed trim cable to IP.
Reworked 10mm bushing to fit upper hinge, hung the rudder.
Figured out how to close the canopy latch, quick clamp. Going to glue wood spacers under the longeron flange to keep from crushing it. also adding a knob to pull canopy in over latch.
Removed front top sheetmetal to gain access to the IP wiring and see if any suprises from yesterdays engine run.
