Brief Description: Set horizontal stabilizer, test run engine
Got the horizontal stabilizer detached from the elevator, (pulled hing pin) and have it clamped. Need to lower the rear 1/2 degree to get it zero.
Did an engine run static test on prop and warmed the engine up good in 12 minutes. All temps stable. This is the first run with the cowl closed up and baffeled. Might need blast tube to get more cabin heat.
