Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Tram wing tips and set horizontal stabilizer
Added static ports to each side of thee plane just aft of the canopy hinges and above the NACA air inlet.
Wings are within 1mm of each other on measure from rudder hinge point.
Wings are level tip to tip by laser and vertical measure from same points Left and Right.
Cut in clearance to get the stabilizer to slide in to position.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
