Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Adding the tail numbers
Clean the area with lacqurer thinner.
Tape the numbers to the line, peel half the backing and cut away, let the numbers down to the clean surface gently and press in place. Remove the tape and the top backing, and let the numbers fall gently in place, press in place.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
