Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fit and cleco inner flashing for the canopy
Clamped clear acetate and drilled through to transfer the exsisting holes to the inner flashing.
Pilot drilled top flange then clecoed inner flashing lower edge.
Clecoed top surface starting from the rear and working forward while using clamps to pull things together.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
