Brief Description: Engine torsional test and static run
Roy from roysgarage.com stoped by today and set up a tooth counter on the harmonic balancer and spliced into the tach pickup leads to gather data on several different run ups.
Afterwards we checked the timing 29 degrees on the A side and 23 degrees on the B side. Full static runup to 2770 RPM with Roy's 66" warp drive prop.
