Brief Description: Mount ELT and rear spinner bulkhead
Made a braket of .04" to hold the ELT brackets. Both ends of the bracket are mounted to the structure of the airframe. It just fits in front of the battery box which will keep it located better fore and aft.
Setup the rear bulkhead in the lathe and removed a few thousands from the center hole.
Used rat tail file to slot holes for the SAE 1 hole pattern.
