Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Carb re-assemble and mount
New gaskest for the throttle body arrived. Checked carb for flatness, within .0015"
Reassembled and torqued it up 25, 35, 40, 45 inch pounds using a cross X pattern.
Set idle screw 2-1/2 turns out.
Set linkage for full and idle stops on the middle hole.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
