Brief Description: Protect wires and cabin heat air deflector
Spiral wrap came in and used some on the brake lines and the main power feed lines.
Made a air deflector to disburse the hot air from a hose clamp with a couple of pieces of 10-32 threaded rod and a piece of aluminum, two nuts on each side hold the plate.
