Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Cabin heat cable
Ran the cabin heat cable and attached the end with a 10-32 bolt with the head drilled for safety wire. Used little bushings with set screws on each side of the bolt head, drilled bolt for cotter key.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
