Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Remove test shroud and start front baffel
After removing the air shroud and cables made up a section of the right front baffel.
Reworked the front starter bracket so the lock nut can be used. Its close but there is clearance and the threads protrude past the nut.
Right front baffel
Section held lower
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
