Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Ignition system
Pulled all plugs and verified distributor placement, points open at 12 degrees.
Marked 16 and 32 degrees Before TDC to set timing.
Bolted Coil Switcher, Coils and Pass Through.
Mark TDC
Mark 16 and 32 degrees BTDC
Switcher, Coils, Pass through
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
