Ron Lendon's Aircraft Mfg.
Date:  9-6-2011
Number of Hours:  2.50
Brief Description:  Heat muff mock up
Trimmed ends of the aluminum heat box mock up and riveted it in place. Should use thin stainless for the final.
Per WW the clearance for engine movement is less than 3/8 with the corvair. He did recommend 1/2 around the heat muff though.
Positioned the cabin heat box on the left side to keep it away from the fuel system.
