Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Heat muff mock up
Trimmed ends of the aluminum heat box mock up and riveted it in place. Should use thin stainless for the final.
Per WW the clearance for engine movement is less than 3/8 with the corvair. He did recommend 1/2 around the heat muff though.
Positioned the cabin heat box on the left side to keep it away from the fuel system.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
