Wrapped .025 around a 7/8 dowel and put in a couple of nut plates. This piece covers the sharp edges flowing into the filter and holds the filter in place. Had to notch the front angle to clear the nut plates for install/removal
Layout rivet pattern on the scoop and transfer it to the bottom cowl skin. Layout air inlets for carb and carb heat.
Riveted air scoop to bottom cowl panel and put a few screws in to have a look.
