Brief Description: Carb heat valve for the air scoop
Used 1/4 HD Felt sandwiched between .040 6061-T6 aluminum, the felt protrudes about 3 - 4 mm beoyund the edge of the plates which are about 3 - 4 mm smaller that the air scoop.
Made a lever from two pieces of .040 also, it and the hinge are sandwiched on the top side of the felt.
