Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Lower Cowl Panels
Transfered the Dzus hole centers to the upper cowl panel.
Opened the Center holes up for the Dzus fastners and riveted the Dzus springs to the C-Chanel/Lower Cowl Panel. Check fit.
Open Screw holes and hinge rivet holes. Dimpled Screw holes. Drilled for Nutplates.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
