Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Align Nose Bowl with Fuselage
Line up the laser light with the fuselage longerons and centerline, checked and adjusted the nosebowl so it presents correctly to the wind.
If you look real close you can see the one degree down and 1/2 degree lateral offset at the prop hub center.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
