Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fitting lower nose bowl
Tucked the shrunk metal under the upper skin. Had to break a couple of tacks but it will look better.
Cutout for inlet.
Just realized I need to reshape the lower piece so the air flow isn't hitting those two triangular flat spots. It is a learning experience.
See the flats, they gotta go
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
