Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Shaping the air inlets
The plate on the bottom support and hold the metal to the Station Buck and give you a change to visualize where to work the metal next. Getting near the end turn and need to soften the outer shape to blend the end turn.
Bottom of Station Buck
the one on the left is softer now
Getting close to the form
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
